How to change the blue background of your MSIX installer logo
Hello everyone,
Recently, I had a user asking me how to remove the blue background of the logo icon in your MSIX package.
Doing some research into this, I honestly could not find much on how to achieve that and so I started testing.
Let's consider you already:
  • created your MSIX package
  • set up the logo icon in the "Package Information" page
  • and then ran the installer. Upon running the installer, you noticed that the logo actually looks like this:
As we can see, the logo is quite small and also the background is blue, so not really pleasant to look at.
After doing a little bit of research, I found out that this color is retrieved from the OS and it is actually the accent color of your Windows.
Personalize your Colors in Windows
The accent color is used to highlight important elements in the user interface, such as buttons, links, and other interactive components.
So, how can we change this?
It's quite simple, actually. All we need to do is go to the "Builds" page --> "App installer" tab and enable the "Use custom UI" option.
There, we can modify the accent color used by the logo.
In our case, we have noticed that in order for the logo to look better, we need a white background not a blue one.
To achieve that, we can se the "Accent color" like so:
#FFFFFF
And now, this is how your icon should look like:
Hope you found this useful! :)
Return to “Sample Projects”
