Re: TeamCity Agent getting stuck building Installer
I just did a random test by installing the latest version, 23.9, in the docker container today and it suddently started working just fine.
When trying to create a new object, it worked just fine:
Note: Ignore the working folder being 23.3, it actually uses the latest one installed.
Also, the dev I am working with on this tested with a clean container, version 23.9 installed, and it worked just fine for him overthere as well.
If we have a look over the screenshots above, regarding teamcity, we can see that I also tested with version 23.9 (our latest one).
Is there a chance you can create a new container with version 23.9 and retest this with that?
Just to make sure I wasn't going insane, I did the following:
- uninstalled 23.3 completely
- installed it again --> tested the creation of a new object --> failed
- uninstalled 23.3
- installed 23.9
- tested the creationg of a new object --> it worked
Did you get a chance to test this?
I'm really curious if everything is working as expected on your end as well now (having my fingers crossed that it does) :D .
dkuerten
Sorry for the delay,
I did manage to test it on a local container and it worked with version 23.9.
Afterwards I immediately wanted to confirm this on the teamcity server as well, but unfortunately the host machine is down since the end of last week. :(
As I have no access to the host directly I am unable to investiges the reason myself. The issue is currently investigated, I checked again today but the machine is still unavailable. Due to people currently being on leave I cannot give an exact estimate when this the machine will be back up again. Once this is resolved I will immediately test it with the newest version and reply my results. I am confident it should work based on the result of my local tests.
Regarding the version issue I also want to confirm something. The reason we are currently using version 23.3 is that this was the newest version when our maintenance expired. Would this mean we are unable to use version 23.9 until we renew our subscription?
No worries about the delay.
I am really glad to hear that everything is working now with the latest version.
I also belive that this will work just fine in the TeamCity container, as I've tested that myself initially and worked without any issues.
Regarding this, could you please write me an email at support at advancedinstaller dot com with the details regarding your license (either the license key or the email under which the license is assigned) - I wasn't able to find it in our database using the email you've used to create this forum account.
