twilight250
getting error: 2716
I'm trying to package a new MSI based on previous installation. In the registry tree, there are some dlls that are generating errors in the Adv Inst when I try to compile the MSI
DEBUG: Error 2716: Couldn't create a random subcomponent name for component 'CommonFilesFolder_Business_Objects_3.0_bin_p3dbtcht.dll'.
MSI (c) (F0:F4): Font created. Charset: Req=0, Ret=0, Font: Req=MS Shell Dlg, Ret=MS Shell Dlg
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2716. The arguments are: CommonFilesFolder_Business_Objects_3.0_bin_p3dbtcht.dll, ,
MSI (s) (94:E4): Product: Crystal11_Redistributables -- The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2716. The arguments are: CommonFilesFolder_Business_Objects
I googled the error, this is what the MSDN says:
2716 Could not create a random subcomponent name for component '[2]'. May occur if the first 40 characters of two or more component names are identical. Ensure that the first 40 characters of component names are unique to the component.
I tried changing the dll name and played around with changing its properties, but the error still comes up. I need those dlls in order for the MSI to work properly.
Cosmin
Re: getting error: 2716
Please note that this error refers to the name of your components, not to the names of the files. The component names can be changed in the Organization page. Let me know if the problem persists when using shorter unique names for your components.
Cosmin
twilight250
ok that seemed to work.
I had long pathnames like this
CommonFilesFolder_Business_Objects_3.0_bin_p3tbtcht.dll
and similar names for 2 different files
CommonFilesFolder_Business_Objects_3.0_bin_p3tbtchs.dll
under Organization, i changed the path name to this
instead of CommonFilesFolder, changed it to CFF
CFF_Business_Objects_3.0_bin_p3tbtcht.dll
ran the compiler again and no errors. thanks for the help.
twilight250
1 more question also
i have about 300 entries that i need to change (the path names, from long to short)
CommonFilesFolder_Business_Objects_3.0_bin_etc.dll
is there a way to mass modify these paths in teh Organization? or can I only change them 1 by 1? It will take me a few hours to do it individually, can I modify in bunches at a time?
Cosmin
I'm afraid that multiple components cannot be renamed at the same time. However, you ca try opening the .AIP file with a text editor and using "Replace" to modify the names of the components.
For example, you can replace:
Component="CommonFilesFolder_Business_Objects
with
Component="BO
so the names of the components which match this criteria become:
BO_3.0_bin_etc.dll
Cosmin
