pethusamy
Creating shortcut for specific language only
Our windows product supports installation in english and Germany languages. During the installation, a desktop shortcut will be created for both the languages. For some reasons, we dont want to create shortcut for Germany language but for english language. Is there any way to achieve this functionality?
Thanks in advance.
GabrielBarbu
Re: Creating shortcut for specific language only
First thing, the shortcuts should each be placed in its own component.
You can then easily use the [ProductLanguage] property to control whether that component is to be installed or not. This can be done from the Organization tab by selecting the component and editing the Condition field from the right pane.
Gabriel
Gabriel Barbu
Advanced Installer Team
pethusamy
thanks for the quick reply. I have selected the ProductCode from ProductInformation topic. Now what should be my condition so that the desktop shortcut will not be created for Germany lanugage?
ProductLanguage ~= Germany -> Is this the right condition?
Please help on this.
GabrielBarbu
The ProductLanguage contains a language code as listed in the following link:
http://www.science.co.il/language/Local ... ?s=country
For example, an english installer has ProductLanguage = 1033
Gabriel
Gabriel Barbu
AKR
How to make so that the files are installed, but the shortcut was created depending on the localization of the system?
You can see a reply in our "Shortcut and files depending on the language" forum thread.
