DEV_cstanden
Upgrade from less features to more features
I have created an installer package with multiple features that are selectedable via the Custom dialog and public properties. This scenario occurs when I have installed a subset of the features and would like to upgrade to all of the features.
In one example:
The installation contains "FeatureA" and "FeatureB"
I have installed the application only with "FeatureA"
I have performed updates, rebuilt the package and now want to install with both features - performing an upgrade by first removing the product.
I have noticed that in this case that a registry value from "FeatureB" is not installed with the upgrade installation
Now I have run this test where the original installation is installed with both features and is successfully upgraded with both features
In the Upgrades tab, the upgrade action for "Enable Migrate Features action" is unchecked.
DEV_cstanden
Re: Upgrade from less features to more features
I have noticed an entry in the log:
MSI (c) (C0:A8) [13:49:26:323]: MigrateFeatureStates: based on existing product, setting feature 'Pricing' to 'Absent' state.
In this case, the feature "Pricing" is my "FeatureB" in the above scenario.
Also I am attempting to run this from the command line in passive mode.
mihai.petcu
I have tested this scenario and it seems you can add the same Upgrade Code in the "Upgrades" page. We will add an improvement regarding this in a future version.
If you don't want the "Migrate Feature States" option activated for your upgrades please follow these steps:
  • in the "Upgrades" page check the "Customize Advanced Installer upgrade rules" option
  • double click on the entry with the OLDPRODUCTS property from the upgrades list and in the "Upgrade Action" tab uncheck the "Enable Migrate Features action" option
