onkeldave
Password Protect Installer Problem
Hello experts,
i cant find a simple password protect for a professional or enterprise "project" (complete project exe file)
no serials or something like that, only a simple password bevor install
can someone explain me how it is?
THANKS A LOT FORWARD
dave
Re: Password Protect Installer Problem
Hi Dave,
Please note that a simple password is much easily to be broken then a serial. As you probably for serial validation we already have a feature available.
If you want only a simple password protection you can try the following:
-- create an Enterprise project
-- go to Dialogs page, on dialog "WelcomDlg"
-- here add a new edit box were the user can enter the password
-- set the property of the editbox to "MY_PASS"
-- now select the "Next" button from same dialog and add a new published event, from the "Published Events" tab, lower side of the page
-- set the event like this:
Argument: <NewDialog>
Condition: MY_PASS <> "here you write the password"
This will make the installer to pass to the next dialog only if the correct password is entered.
bsflasher
How can I do this ?
In order to achieve this, please have a look on the following screenshot:
which hopefully will help you to create the event.
After following the steps described in the screenshot, simply follow the instructions given by my colleague Bogdan.
Hishiro
Hi!
Im try creat a simple password but not work. Pls help
I want after welcome dialog show, next button is disable. In welcom dialog, i creat a edit box Enter password. When user enter password match next button enable.
Pls help me creat it.
I've replied to the other forum post you added which is similar to this one.
