Some users are getting a "Network Resource Error" when they try to upgrade versions. This is with exe's that extract to "[AppDataFolder][|Manufacturer]\[|ProductName]\install". It fails and tries to browse to this location to find the older msi. This does not happen if the user installs the older version then immediately installs the newer one. It happens with users that have had the older version installed previously and are trying to use the new installer. It will also make the user unable to install the older version through any means but rerunning the original exe (Control Panel, Uninstall Shortcut, etc. don't work).
Anybody have any ideas on how to try to fix this problem?
Pat
