rho
Share files among multiple MSIs
I've two MSIs: client and server, where one component is the same, containing framework files. they need to be in both installers.
Additionally, both MSIs are installed to the same directory.
How can I make sure, that the framework files are not removed, if both MSIs are already installed, and one of them should be uninstalled?
Cosmin
Re: Share files among multiple MSIs
Make sure that the component has the same name and GUID in both installers. This way Windows Installer will use a reference count for it (it will be removed only when all packages which contain it are uninstalled).
Cosmin
rho
thanks, this sounds good.
How can I put multiple files into one component?
Simply go to Organization page, locate the file you are interested in and drag and drop it in the component you want it to be placed.
rho
when adding the files, each of them is placed in its own component. and as soon as it has the key symbol on it, I can't move it nowhere. It's also very extensive to reorg lots of files one by one.
- Is there a way to move a key resource to another component?
- is there a way to add multiple files to one component when adding them?
edit:
found out, that files which are being referenced somewhere can't be moved.
rho
a further question:
has it any restrictions on later patching capabilities when I put multiple files into one component? like "the patch has to contain all files which are grouped in the component to patch, to not loose other files" ?
Cosmin
Files which already have their own component don't need to be moved. You can use the component directly.
Components are generated automatically based on Microsoft best practices. But you can always reorganize them any way you want. To move a file to an existing component, simply drag that file over the component item. Please note that not all components support this.
No, there shouldn't be any restrictions. A patch includes the difference between two MSI packages. So if a file was changed, it will be included in the patch.
Cosmin
