derfsplat
IIS VDirs don't appear to work with more that 2 VDirs
I'm not sure if I am the only one experiencing this, but as soon as I add more than 2 virtual directories to the IIS portion of my aip file, Advanced Installer fails to build with the following error:
Building package (en): \\Epssvc1\INSTALL_STAGING\Field-Comm\Field-CommServer.msi
Creating CAB file(s)... done.
Creating MSI database... error.
Exception - Reason: Error calling Msi API: 1627 Method: MsiDatabaseCommit Table: none.
The progress stops at adding tables to the MSI database with the detailed progress labeled "Adding AI_IIsVirtualDirectory table rows."
Is there a work around to this? Am I the only one experiencing this problem? I can send you the aip file but it's rather large and I'd rather not post it to the forum.
I am using the latest version of Advanced Installer (v4.6).
Please help!
-Fred
gigi
Hi Fred,
Please send a zipped archive containing the .AIP project file, if it doesn't contain any confidential information or a similar, simplified project reproducing the issue.
This will help us greatly to provide a solution in the shortest possible time.
Kind Regards,
Gigi
______________
Gheorghe Rada
Advanced Installer Team
derfsplat
I've sent an email to support at advancedinstaller dot com referencing this post.
gigi
Hi Fred,
This is a bug due to a Windows Installer limitation, the fix will be available in a future release (most probably at the beginning of the next week). Thank you for bringing this to our attention.
Kind Regards,
Gigi
______________
Gheorghe Rada
derfsplat
Excellent! Glad to hear I was able to help improve an already exceptional product :)
