First you need to make sure that you are using an Enterprise or Architect project. If you are not, you can change the project type through
Project -> Options application menu. After that, you can select "Dialogs" page in left menu to see all the installation dialogs.
You can then select each dialog, select the "Advanced Installer" static text control and delete it.
Cosmin
