rconn
Orca validation errors
I'm running the Orca validation tool on the installer file (.msi) created by Advanced Installer (4.8.1). It is generating 3 ICE45 warnings:
Row 'VerifyRepairDlg.Repair' in table 'Control' has bits set in the 'Attributes' column that are reserved. They should be 0 to ensure compatibility with future installer versions.
Row 'VerifyReadyDlg.Install' in table 'Control' has bits set in the 'Attributes' column that are reserved. They should be 0 to ensure compatibility with future installer versions.
Row 'VerifyRemoveDlg.Remove' in table 'Control' has bits set in the 'Attributes' column that are reserved. They should be 0 to ensure compatibility with future installer versions.
The attribute Orca is complaining about is 0x00800003 for all three.
I could reset the attributes in Orca, but (1) I don't know what attributes Orca is complaining about, and (2) I'd have to do it every time I built a new installer.
(I need to get a clean validation in order to meet the Microsoft requirements for a certified app.)
Rex Conn
JP Software
gigi
Hi Rex,
Those ICE warnings are due to the ElevationShield Attribute set for the "Install", "Repair" and "Remove" buttons from the respective dialogs. This attribute is required in Windows Vista - it will add the UAC elevation shield icon to the button controls when the package runs in Vista (as recommended by Microsoft).
The ICEs that are installed with the latest version of Orca have not been updated for the Windows Installer 4.0 MSI schema, hence indicating that the respective values are reserved for future use.
You should not be concerned about these warnings, as Microsoft will probably issue updated ICEs soon.
Gigi
______________
Gheorghe Rada
Advanced Installer Team
wyzerd
Re: Orca validation errors
I was reading this "updated soon" comment and realized it was 3 years ago.
Is there a new .cub that can be downloaded?
GabrielBarbu
Are you receiving the same errors? Can you give me more details about the problems you are encountering? Also, please make sure you have the latest Windows SDK installed on your computer.
Gabriel
Gabriel Barbu
wyzerd
Yes, I just got the 4.5 SDK and ICE27 still is in the list. Unknown action 'MsiConfigureServices'
Also having significant issues with every file in Merge module showing as compressed creating ICE39 warnings as well as duplicate sequence errors from same causing ICE82s.
Sorry for the delay.
Cosmin
The "MsiConfigureServices" action was added in Windows Installer 5.0 and it's not recognized by older versions of Orca. Also, Microsoft hasn't released an Orca version which covers Windows Installer 5.0 yet. So the ICE27 error should be ignored.
The ICE39 warnings are shown because the merge module files are marked as compressed by default and the MSI is also marked as compressed. This doesn't affect the package functionality, it simply informs you about the duplicate flags. A future version of Advanced Installer will include an improvement which avoids this warning.
The ICE82 warnings appear because the "Common Application Data\CMS" and "Program Files\CMS" folders are created in your main project and in the merge modules, even though they are empty in the main project. To avoid the warnings you can try deleting these empty folders from your main project.
Cosmin
