khicks
Adobe Flash Player 13 ActiveX Installer
Hi, Hoping to get some help with this software.
Downloaded the latest Adobe flash MSI from http://helpx.adobe.com/flash-player/kb/ ... d_versions
Created a response transform for the active X Msi.
It appears that this msi unpacks some files from itself into the %temp% folder. The MSI is basically a wrapper for the exe.
However, when I run the transform, it looks under whatever the root folder for the transform is. In My case C:\_Packaging\tempfolder\installAX_13_0_0_206.exe. It appears to be plugging in some variable in front of the %temp%. Of course the file does not exist in that location ending in an error 1309.
Is there a way to fix this? I am new to this software but have been packaging for some time. Using wise I do not get these errors creating a transform on this same MSI.
Is there a setting I can change or something I can do besides manually going through all the custom actions and attempting to change it there?
Re: Adobe Flash Player 13 ActiveX Installer
I've tested the scenario against "flashplayer13_0r0_206_winax.msi" file, but I could not replicate the related behavior. Can you please give us a detailed step by step test case (maybe exemplify or attach some screen shots) which we can follow to replicate the behavior?
khicks
Step by Step.
You are correct it works as it should until I make a change in the transform. This can be any change. Here is a step by step.
1. New Response Transform.
2. Transform Wizard (the error also happens if I do a basic transform (save msi as MST)).
3. Navigate to flashplayer13_0r0_206_winax.msi and select
4. Set Path for MST.
5. Next, Next, Finish install.
6.Response transform Contect (see untitled.png)
7. NExt, Next Finish.
Open the MST.
1. Select the MSI.
2. Test the MST. No changes and it installs properly.
3. Add MMS.CFG to Windows Volume\windows\system\macromed\flash\ (included as mms.txt, although any change to the mst creates the issue).
4. save MST. Run install using either cmd file or through interface.
Receive error 1309 reading from file. Because it does not exist in the directory. see untitled2.png.
Any input would be greatly appreciated.
Kenny
mms.txt
(47 Bytes) Downloaded 532 times
Screenshots of Step by Step in word document.
I've tested and indeed I can replicate the related behavior. Please give us some time to investigate this and I'll get back to you as soon as we have a conclusive answer.
Hello Kenny,
After further analyzing this scenario it seems the related behavior is caused by an Advanced Installer limitation. A fix will be added in a future version of Advanced Installer, thank you for bringing this to our attention. We'll notify you when the fix will be out. Until then as a workaround you can proceed like this:
- opening the MST file for editing in Advanced Installer and add the MMS.CFG file in "Files and Folders" page
- go to "Table Editor" page, select the "File" table and set (for all files within "File" table) the "Attributes" column to the following value:
- right click on the "Media" table and uncheck the "Ignore in Transforms" option
- save your MST
This was fixed in version 11.6 of Advanced Installer released on October 23rd, 2014.
