vybhav
"Try" , "Register" and "Buy" buttons and text invisible
I am developing a software using C++ and I just created a build to include free trial for 30 days. After I create everything, install the software and run the executable, the the following screen(please see attachment) is visible when I start the application.
Here I see that the Try, Register and buy options are not visible! However when I click on where they should be the corresponding actions happen. So I'm confused as to what I am missing.
The C++ code that I have included is identical to what is specified here -> http://www.advancedinstaller.com/user-g ... using.html
Can anyone please help?
Vybhav
Screen Shot 2015-03-16 at 2.06.24 pm.png (29.75 KiB) Viewed 4247 times
Re: "Try" , "Register" and "Buy" buttons and text invisible
This may happen if your application manifest doesn't include "Microsoft.Windows.Common-Controls" version 6.0. Please take a look on our "Error in License module" thread which may be useful for you.
vybhav
Hello Daniel,
Thank you for your reply. Do I need to add the manifest to the Advaned installer setup file or my original C++ program?
Vybhav
vybhav
I checked the manifest file of my setup.exe file, and it looks like it has "Common controls" already present. Can you please let me know if I'm looking at the right file?
Vybhav
Screen Shot 2015-03-17 at 5.15.34 pm.png (91.79 KiB) Viewed 4222 times
vybhav
Any help on this what be very helpful! Thanks!
vybhav
Hey,
Just wanted to let you know that it got solved when I added this manifest file to my .exe file, before creating the setup file.
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<!-- Copyright © 1981-2001 Microsoft Corporation -->
<assembly manifestVersion="1.0" xmlns="urn:schemas-microsoft-com:asm.v1">
<assemblyIdentity
type="win32"
name="MSIExec"
version="4.0.0.0"
processorArchitecture="x86"
<description> Windows installer setup service </description>
<dependency>
<dependentAssembly>
<assemblyIdentity
type="win32"
name="Microsoft.Windows.Common-Controls"
version="6.0.0.0"
publicKeyToken="6595b64144ccf1df"
language="*"
processorArchitecture="x86"/>
</dependentAssembly>
</dependency>
</assembly>
Thanks for your help Daniel!
Vybhav
You're welcome Vybhav. I'm glad you got this working.
