Hi
I have a filemaker runtime solution. I have a previous version installed with Advanced installer, built as a Simple installer. It always works fine, installing as an upgrade th the previous version or a new install.
But with this new version I just created after installing (uninstalling the old version first, then installing the new version) when I try to run the program it says it can't because Xerces-c_3_0.dll is missing. If I run the installer again and do a Repair that files does get installed and all is fine. If I run the installer on a computer where the previous version does not exist (new install), it installs fine the first time.
I have tried this a few times and it happens exactly the same way each time. I also changed the installer from Simple to Professional and it still happens the exact same way.
The version is 11.8 build 62156.
The problem occurs when installing on Windows 8.1
The install is very simple, nothing fancy except that because of Windows 8,1 securities I have to give the Filemaker database extra permissions so the user can write to it. The problem occurred before I changed the installer to Professional and added the security change. The installer also creates desktop and start menu shortcuts to the .exe.
Any ideas why it would skip this one file during an upgrade?
EDIT: More info
I've tried this on Windows 7 and it works fine.
I've tried it on additional Windows 8 computers and the same error always occurs.
This seems to be the problem line in the verbose log:
MSI (s) (A8:4C) [09:55:41:725]: WIN64DUALFOLDERS: Substitution in 'C:\Program Files (x86)\Sound Ideas\Sound Ideas Sound Effects Search\xerces-c_3_0.dll' folder had been blocked by the 1 mask argument (the folder pair's iSwapAttrib member = 0).
But I will attach the log and the aip file.
Thanks!
Scott
