Server
Service
Engine
Host
Context > docBase
That works perfectly, however as a side effect the following is modified:
Server
Service
Connector
Connector
Connector
From server.xml after the installation:
<!-- A "Connector" using the shared thread pool-->
<Connector executor="tomcatThreadPool" port="8009" protocol="AJP/1.3" connectionTimeout="20000" redirectPort="8443"/>
<!-- Define a SSL HTTP/1.1 Connector on port 8443
This connector uses the JSSE configuration, when using APR, the
connector should be using the OpenSSL style configuration
described in the APR documentation -->
<Connector port="8443" protocol="HTTP/1.1" SSLEnabled="true"
maxThreads="150" scheme="https" secure="true"
keystoreFile="vrm.keystore" keystorePass="********"
clientAuth="false" sslProtocol="TLS"/>
<!-- Define an AJP 1.3 Connector on port 8009 -->
<Connector port="8009" protocol="AJP/1.3" redirectPort="8443"/>
port="8080" protocol="HTTP/1.1"
