tomas.maruska
Keyboard shortcuts handling
Hi guys,
I want to open some kind of installation guide when user hit 'F1' key, basically on every installation page. Opening document should goes through custom action, to consider language version of guide and other rules.
Is something like this even possible? Can I handle keyboard shortcut somehow?
I'm using AI v11.6.3, setup has classic theme.
Tomas Maruska
gamanet.com
Re: Keyboard shortcuts handling
Hi Tomas,
I'm afraid you cannot interact with the installer through a keyboard pressed key event.
However, you can implement your scenario using the published events mechanism. In your case, you can have a Help pushbutton control on each dialog. When the control will be pressed, a custom action will be fired that will launch the help file. For details, please take a look on the How do I execute a custom action when a button is pushed? article which may be useful to you.
Also, the help files needs to be added as temporary files. Temporary Files are copied on the target machine at the beginning of the installation and are deleted at the end of it, ensuring you have access to them throughout the entire install process.
In order to launch the help file, you can use the predefined launch File custom action.
Since you are creating a multilanguage installation package, you can condition the execution of each custom action through the ProductLanguage property.
tomas.maruska
Hi Dan,
First of all, thanks for quick reply.
I'm already using buttons to show Installation Guide. We have pdf file on installation medium, so I find it and open it using custom action. This already works. I was just wondering, whether I can handle keyboard shortcut somehow.
Thank you anyway.
Tomas Maruska
You're welcome Tomas,
