ideeeyut
Unknown publisher
When I download my installer through Internet Explorer I'm getting the User Account Control prompt saying Unknown Publisher. After researching your support forums, we have tried a new SHA2 digital signature certificate we are using to sign the installer. Additionally I have the certificate in the Current User Personal Certificates store and Advanced Installer (10.9) is set to use the Most suited certificate from the system store. I've also made sure that Description and Description URL are both populated along with a Time Stamp URL.
At this point I'm out of ideas. We are still getting the Unknown Publisher prompt. Any help would be appreciated. Thanks.
Re: Unknown publisher
I'm not sure why you encountered this behaviour.
In order to further investigate this, can you please send us a download link of the setup package to support at advancedinstaller dot com?
Hi Scot,
Please note that you are using a timestamp to Verisign which is a SHA-1 timestamp. So, although you have a SHA-2 certificate you are using a SHA-1 timestamp.
To fix this, please use the: http://timestamp.digicert.com as timestamp
Let us know if you have other questions.
