mconstantino
Silent update fails
When i try to install an update silently i always get an error. Consulting the event log i see this:
Produto: KwanzaGest -- Erro 4106. An error was encountered while creating a scheduled task: 'updater.job'. Error description: No mapping between account names and security IDs was done.
This does *not* happen when i install with the full GUI
I am attaching the 1.0, 1.0.1 and UpdateFile projects
Oxn.Installer.rar
(67.97 KiB) Downloaded 225 times
Re: Silent update fails
We are not sure why you encountered this behaviour. Can you please send us a complete verbose log of the installation to support at advancedinstaller dot com so we can investigate it?
Also, could you reproduce this behavior on multiple machines?
Thank you for your sent log. After further investigating your uploaded setup projects (AIPs) it seems this issue happens because you have enabled the "Run only if this user is logged on" option when configured the scheduled task of your Updater in "Updater" pages. Can you please proceed like this
1. go to "Updater" page and under the "Updater Execution" section click on "Configure Task" hyperlink
2. go to "Account" tab and uncheck the "User" field empty (just delete the existing "[%USERDOMAIN]\[LogonUser]" references).
and let us know if this helped?
Please take a look on our "Why the installation fails with the "No mapping between account names and security IDs was done" error?" faq for more details.
