Guest
Banner & Dialog Images get stretched
I am currently testing this product and so far I'm very happy with it. However, what I noticed is that the Banner and Dialog images look great in the preview window, but when I build and run the msi file those images look distorted and have strange lines going through them.
I have done some testing and it looks like those images do get stretched automatically, so when I e.g. change the windows text-size the window is larger and the images get stretched to use the full window.
As this is causing the images to look bad I would like to disable this, so that the images get displayed in a fixed size and do not get stretched. Is there any way to do this?
Thank you.
Cata
The Banner sized are expressed in Dialog Units, which depend on the font size.
If the sizes were expressed in fixed units (pixels), the banners would remain very small when the dialog would grow large on a computer with font size set to Large.
We actually had that before and changed it in 2.4
Cata
Guest
Ok, I can understand that. However, is there anything I can do to change that back? Maybe modifying the template.msi file?
Thank you.
Cata
Argh!!!
Are you sure you want that? We changed it because we kept getting complains from people about how it looked with Large fonts.
But if you are sure about it, send me an email to support at advanced installer dot com and I'll reply with a custom template.msi
Cata
Guest
Yes, I would like to have that custom template.msi file. I have already sent you an e-mail.
Thank you.
