Mike@Nestor
Modify feature at runtime
Hello !
Sorry if my question has already been asked but I don't succeed in what I want, and after many searches over the forum I did not find any answer.
The problem that I'm facing to is simple :
For my install the customer has to use a dongle from which I can know which features he can access to. So then I have to disable the features he can't access to in the customize dialog.
For this need I created a project that use a custom action written in C#.
What I understand from all what I read is : please correct me if I'm wrong
- I can't enable a feature after "Path Resolution" stage for a custom action with sequence.
- I can disable a feature from a custom action without sequence
- I cannot enable a feature that was previously disabled
So I create a project with 2 features (Feature1 & Feature2) and a custom action that display a message box which ask the user to update or not the features. If the user answer Yes, Feature1 is set to 1, Feature2 is set to 0. If he answer No, features do not change.
The custom action with sequence is first called before "search" stage then the same custom action without sequence is called before the customize dialog.
I tried all possible scenarios with features initially set to 0 or to 1 and I never obtained what I want. Sometimes both features are completely disabled, sometimes completely enabled.
If you can help me on this issue it would be great. I let the AI project with the custom action source code. I am working with AI 21.5.1 (enterprise licence).
regards,
Michael
AI_test_features_runtime.zip
(5.71 KiB) Downloaded 32 times
Mike@Nestor
Re: Modify feature at runtime
I found the solution as described as this post viewtopic.php?p=3848#3848
Mike
Hello Mike and welcome to our forums,
If you have any other questions, please let us know.
Mike@Nestor
yes I have other questions.
In a standard installation project I use the SetupTypeDlg dialog with Typical, Custom and Complete installation types.
From my custom action, after reading my dongle, for each feature that user cannot access, I request a new state as Absent (WixToolset.Dtf.WindowsInstaller.InstallState.Absent) and I update the Feature table fields Display and Level respectively with values 0 and 1001, which means to not display these disabled features and prevent their installation from Typical and Complete installations.
So from the Custom installation dialog I don't have access to these disabled features, perfect.
The problem is that the disabled feature are still installed if I choose Typical or Complete installation.
What am I missing ?
regards,
Mike
Hello Mike,
I'm not sure why this happens.
To facilitate a more in-depth investigation of this issue, could you kindly email the following resources to support at advancedinstaller dot com?
1. the .AIP (setup project) file.
2. a download link for your setup package.
3. a test-case that we can follow.
Mike@Nestor
Hello Liviu,
I changed my project, I remove the SetupTypeDlg dialog, so I use only the CustomizeDlg dialog and all work fine, as I want :)
regards
Hello Mike,
Thank you for your followup on this. I'm glad you found a solution.
