michbar89
setup runs after every reboot
Why does the installer run every time I reboot? I want that If i successfully installed the service + prerequisites, then it doesn't get the setup page (for repair or remove) everytime i reboot.
how can I stop this setting?
mihai.petcu
Re: setup runs after every reboot
You can conditionally set the REBOOT property depending on your requirements. You can find more about REBOOT property under the following MSDN link:
http://msdn.microsoft.com/en-us/library/aa371101.aspx
Zachsdaddy
Mihai, I'm not sure you understood this question because this response does not address the issue at all.
I have the same issue.
I have an enterprise install with several prerequisite repackaged MSI installs.
After successfully completing the install, every time the system reboots the setup starts up in maintenance mode. There is no entry in HKCU/Software/MS/Win/Curr/Run for the setup (there is one for one of the services (tomcat6) that was installed, but it runs separately).
But regardless the setup begins in maintenance upon each restart and I cannot figure out why. The prereq wizard does not start, it just goes straight into the install in maintenance mode.
Any help you can offer would be appreciated as I am kind of hung up on this one.
Jt
hondong
Hi There,
after looking at the same Issue in our Setup, i saw this Post :)
We use Advanced Installer 8.9
I think this is an Issue from this version.
We will no downgrade and try again...
kinde regards, Nils
mihai.petcu
Hi All and welcome to Advanced Installer forums,
Can you please send us the .AIP ( project file ) and a verbose log of the installation to support at advancedinstaller dot com so we can investigate them?
Best,
hondong
Hi there,
first of all:downgrade to 8.8.2 solves the Problem.
I saw the Problem only on a fresh Installed Windows Server 2008 and 2008 R2
An existing Server didn´t had the Problem
Maybe this helps to find the Bug.
Attached are 2 Log Files (verbose)
setup is from the first run.
after_reboot = as the name says ;)
setup.zip
(476.79 KiB) Downloaded 473 times
after_reboot.txt
(189.41 KiB) Downloaded 489 times
Hi guys,
We made some tests and found a bug regarding this problem in packages that are using Enhanced UI in version 8.9. We've made a fix, which will be officially
available in version 9.0.
To use it in 8.9 please download the following file and place it in the install folder of Advanced Installer 8.9 on your machines, replacing the original one. After
this restart Advanced Installer and rebuild the projects.
http://dl.dropbox.com/u/5392761/Advance ... rnalUi.exe
Zachsdaddy
What install folder are you referring to?
I do not see ExternalUI.exe in the "C:\Program Files (x86)\Caphyon\Advanced Installer 8.9" path.
Am I missing something here?
Zachsdaddy
Do you mean this one?
C:\Program Files (x86)\Caphyon\Advanced Installer 8.9\stubs\x86u
Yes, that is the path.
Zachsdaddy
Just tested your fix. It worked.
Thanks so much
Jt
Maverick
I had the same problem , too.
I have tried the fix and the fix is working.
Great. Thanks
StefanB
i'm having the same issues, but can't download the ExternalUI.exe from your link.
I can't update to a newer fixed version because our maintenance plan is expired.
Where can i get the needed bugfix?
Regards
mihai.petcu
Just contact us by e-mail to support at advancedinstaller dot com mentioning this issue.
The above link has been repaired so the fixed file can be downloaded now.
