I am trying to run SQLEXPR.EXE in custom action install and i works fine until i add Sql script.
Sql scripts is runing before SQLEXPR.EXE.
Is it possible to move SQL scripts Execution after Custom action SQLEXPR.exe execution?
Note that you cannot move a standard action, but you can move the custom actions you use. If you need to see a standard action you can use the "Show Standard Action" button on the toolbar in the Custom Actions page.Is it possible to move SQL scripts Execution after Custom action SQLEXPR.exe execution?
