Collins
Ability To View Edit Field Value With Password Attribute Set
Can the ability be added to unmask the value of an edit field that has the password attribute set with a push button. For instance, I have a value that is not necessarily a password (API Key) that is complex and that I want hidden, but I would like to validate its accuracy by pushing a view button and once its released, it becomes masked again on the dialog.
Re: Ability To View Edit Field Value With Password Attribute Set
Hello Les,
We already have an improvement regarding this (password "peek") on our TODO list of improvements.
However, this will only be possible by using the WinUI feature, because the Windows Installer does not support such scenario. The only problem with this would be that WinUI only works on Windows 10 and above.
For MSI, the only thing I can think of would be displaying a messagebox when the "PushButton" control is pressed.
Collins
Catalin wrote: Mon Apr 18, 2022 9:28 am Hello Les,
Thanks Catalin. I have tried the PushButton approach, but the PROP that sets the value still logs that value based on my attempt. It would be helpful if there was an AI CA that could display that without logging it.
Hello Les,
I am not quite sure I fully understand this.
Do you mean that the property appears in the log file?
Collins
Catalin wrote: Wed Apr 20, 2022 3:42 pm Hello Les,
Catalin,
That's correct.
Hello Les,
Have you tried setting the "Hide property" attribute for your property?
This should prevent the property from being displayed in the log file.
As per my tests, the property is not displayed in the log file. Its value is, however, displayed in the log file if you search for the "MessageBox" custom action and then check the value of "CustomActionData" property.
Collins
I did not set that attribute on the property that was on the message box, but I do remember seeing the value in the log file.
Hello Les,
Have you tried setting the attribute I mentioned above for the property?
That should prevent it from being written in the log file.
Collins
Sorry for the late response. Yes, setting the Hide Property works .
Hello Les,
No worries!
I am glad to hear it worked.
Return to “Feature Requests”
