Hello
I am using the free version of advanced installer.
I need to put the same set keys into HKLM\SOFTWARE and HKLM\SOFTWARE\Wow6432Node
I have created a registry file, which works when I run it manually. But if I import that registry file
into Advanced Installer it wont work after building. It only puts the keys into HKLM\SOFTWARE\Wow6432Node.
I aslo tried to put a script that runs the registry file into RunOnce, which if I do it manually works fine, but
if I try to use the program the RunOnce key never appears there.
Hope somebody can assist me.
Hope I am clear enough
