zemer
How to get %ERRORLEVEL% for Jenkins based on build command output?
hello,
im building my project using AI cmd inside my jenkins pipeline using :
"AdvancedInstaller.com /build "my project.aip".
how do i catch any error code from AI command line output in order to fail jenkins pipeline build ?
Re: How to get %ERRORLEVEL% for Jenkins based on build command output?
Hello Zemer and welcome to our forums,
For example, when the build process is a success, then the return code should be "0". For example, if you try to build a .AIP file using the following command:
AdvancedInstaller.com /build "D:\SomeAip.aip"
echo %errorlevel%
pause
if the build succeeds, the %errorlevel% will have a value of "0", otherwise it means that the build process fails.
You're always welcome, Zemer.
I am glad I could help.
