don_ucw
Set project root path from command line
Our build machine has installer inputs in a different folder structure than our development machines. We are using AI command line to do the builds.
Is there a way on the AI command line to set the project root path?
I tried using path variables, but since there are a number of folders, it get complicated quickly.
Sorin
Re: Set project root path from command line
Unfortunately we don't support for changing the project root path through command line. I have added this improvement on our TODO list and it will be available in a future version of Advanced Installer. Thank you for your understanding.
Don't hesitate to contact me if you have any other questions.
Sorin
don_ucw
Thanks Sorin
Sorin
You are welcome!
We will update this thread when the feature will be available.
Sorin
berqo127
Is there any update with this feature?
Shlomi
Hello Shlomi,
Unfortunately, this improvement was still not added, due to the fact that it had a low priority in our improvements management system.
However, I have now increased its priority and hopefully it will be added in a future version of Advanced Installer.
Kind regards,
