gazunk
PowerShell build problems
I'm trying to build an installer from scratch using Powershell, for use in a multi-project CI system. I am following this tutorial: https://www.advancedinstaller.com/user- ... ation.html
This simple script fails:
$project = $advinst.CreateProjects("professional")
$project.ProductDetails.Name="$PROJECT_TITLE"
$project.ProductDetails.Publisher="Company Limited"
$project.ProductDetails.Version="$PROJECT_VERSION"
$project.FilesComponent.AddFolderContentS("APPDIR","build\bin")
$project.SaveAs("Installer.aip")
Firstly,
does not list any files (or any information) as the tutorial suggests it should.
Then, saving the project produces this error message:
Error opening file: "Installer.aip".
At <script location>
+ $project.SaveAs("Installer.aip")
    + CategoryInfo          : OperationStopped: (:) [], COMException
    + FullyQualifiedErrorId : System.Runtime.InteropServices.COMException
This occurs on 18.4 and 18.5
The documentation for ProductCode also seems confusing (GetProductCode and UpdateProductCode "Adds a new file in the project and returns the file as an object"?): https://www.advancedinstaller.com/user- ... tcode.html
Re: PowerShell build problems
Firstly,
The correct command here is "$project.FilesComponent.Files" as detailed in our tutorial.
This error appears because you don't give the path of the location where you want the project to be saved. You need to use:
$project.SaveAs(“C:\Sample\Installer.aip”)
Also, the first command should be "$advinst = New-Object -ComObject AdvancedInstaller" to create a new COM object of type Advanced Installer.
This is your script adapted:
$project.ProductDetails.Name="Test"
$project.ProductDetails.Version="1.0.0"
$project.FilesComponent.AddFolderContents("APPDIR","D:\test powershell cmd\resources")
$project.SaveAs(“D:\test powershell cmd\Installer.aip”)
Indeed, the documentation is misleading. I’m sorry for that, we will update it.
The correct command here is:
$project.ProductDetails.ProductCode.GetProductCode()
Hope this helps! If you have any other questions, please don't hesitate to contact us.
gazunk
Thanks for the reply! I did instantiate $advinst, but it looks like you called the other errors correctly, ta.
You are always welcome!
Please let us know if there is anything else we could help you with and we will gladly assist.
SZLMCL
After I update AI to the latest version, the COM object call throws an exception:
$advinst = new-object -ComObject AdvancedInstaller
0x80040154 (R
EGDB_E_CLASSNOTREG)
Before install new version it worked fine.
How can I register the AI COM object manually to make this work again?
Thank you!
Usually, AI COM uses the latest version installed on the system.
To register the latest AI version you want to use for COM, please follow these steps:
  1. Open an elevated Command Prompt.
    • Use the following command:
      "C:\Program Files (x86)\Caphyon\Advanced Installer 20.4.1\bin\x86\advinst.exe" /REGSERVER
      Use upper-case letters for "/REGSERVER".
      If you want to use another AI version, just use the above command. Go to the version you want to use and you can find the advinst.exe in "\bin\x86\".
      • Restart the PowerShell session and now you can build with the 20.4.1 version inside your script.
      SZLMCL
      Liviu wrote: Tue Mar 21, 2023 4:24 pm Hello,
          Works fine, thank you!
          You're always welcome!
