Jacob Darka
Run commands of batch file directly through installer
Is there any way to run the commands of a batch file directly through the installer itself, without the need of an actual .bat file?
For example, I got a batch file that does the following:
ren "5.txt" "5.back"
move "5.back" "temp"
Now I want to integrate these very specific commands through the installer itself, is that possible?
Re: Run commands of batch file directly through installer
Hello Jacob,
I believe you could achieve that by using a "Launch File" custom action that launches the cmd.exe and then pass those as arguments.
Besides that, you could convert that to either VBScript or PowerShell (this would also be much easier) and use one of the following custom actions:
Run Inline PowerShell script
Execute inline script code
Jacob Darka
Thanks for the answer Catalin.
You are always welcome, Jacob!
