a.varantes
VS2017 AIP Extension Error
I'm trying to create an AdvancedInstaller project on my solution, using VS2017 and AI 14.3.
On my first try I was able to add the project and add project outpts as well.
At my second try, when I try to add a new AI project an error appears and I can do nothing more:
ERROR:
Microsoft Visual Studio
Retrieving the COM class factory for component with CLSID {F6D69C22-C70F-416D-80E6-DBA6A90B56C7} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
OK
Can someone help me here please, thank you in advance,
Best regards
Re: VS2017 AIP Extension Error
Can you please try to update to the latest version of Advanced Installer and see if the behavior persists? We had a similar problem which was discussed on Visual Studio 2017 Build Issue thread and it was fixed in the 15.3 version of Advanced Installer.
You can download older versions of Visual Studio extensions from Advanced Installer Extension for Visual Studio page. For older versions of Advanced Installer you can check the Customer Information page.
a.varantes
Hello Liviu,
Thanks for the feedback
Best regards
You are always welcome!
Please let us know if there is anything else we could help you with and we will gladly assist.
