AndyL
Error from AI_IIsConfig after upgrading to Advanced Installer 19
We have an installer that configures IIS, and creates an app pool and web app.
For versions 1, 2 and 3 of our product, we built the installer in AI 17.9. Each time, we just change the version numbers and product codes, and obviously the files that get installed. The installer itself has no other changes.
For version 4 of our product, we did the same except this time we used AI 19.0.
Now we seem to be getting an IIS configuration error when doing an upgrade installation, that we didn't get with the previous versions. (A clean install still works fine.)
Test scenario 1:
  1. Start with a clean, blank Windows 10 VM.
  2. Install product version 1.
  3. Browse to web app and check it's working.
  4. Run installer for product version 3 and do an upgrade of the previous install.
This works without any problems.
Test scenario 2:
  4. Run installer for product version 4 and do an upgrade of the previous install.
This fails with an error message something like "There was an error during the IIS configuration process while trying to install application pool".
I've compared the logs from the successful version 3 upgrade and the failed version 4 upgrade, and this is an extract from the failed upgrade where they diverge:
MSI (s) (DC:84) [14:11:25:337]: Executing op: ActionStart(Name=AI_IIsConfig,Description=Configuring Internet Information Services,Template=Installing "[1]")
MSI (s) (DC:84) [14:11:25:340]: Executing op: CustomActionSchedule(Action=AI_IIsConfig,ActionType=11265,Source=BinaryData,Target=**********,CustomActionData=**********)
MSI (s) (DC:AC) [14:11:25:344]: Invoking remote custom action. DLL: C:\Windows\Installer\MSI3ECA.tmp, Entrypoint: OnIIsConfig
[OPERATION]Application pool 'ProductX App Pool'
[INFO] Installing Application pool...
[INFO] Trying to retrieve 'ProductX App Pool' Application Pool...
[OK] Found AppPool.
[INFO] ApplicationPool 'ProductX App Pool' already exists !
[WARN] Skipping Application Pool Install...
[INFO] Updating common headers to 'MACHINE/WEBROOT/APPHOST'.
[INFO] Committing changes to path 'MACHINE/WEBROOT/APPHOST'...
 COM Error [0x80070020]: (The process cannot access the file because it is being used by another process.)[ERR] Cannot execute Commit operation.
 COM Error [0xffffffff]: (Unknown error 0xFFFFFFFF)[ERR] Cannot execute Commit operation.
MSI (s) (DC!80) [14:11:59:509]: Product: Acuity STREAM Web API -- Error 4034. There was an error during the IIS configuration process while trying to install Application pool 'ProductX App Pool'.
Your original IIS configuration will be restored.
CustomAction AI_IIsConfig returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
Action ended 14:11:59: InstallFinalize. Return value 3.
Has there been any change to this custom action between 17.9 and 19.0 that might explain the different behaviour?
AndyL
Re: Error from AI_IIsConfig after upgrading to Advanced Installer 19
Another test case which provided an interesting different result:
  4. Run installer for product version 2 or 3 and do an upgrade of the previous install.
  5. Browse to web app and check it's working.
  6. Run installer for product version 4 and do an upgrade of the previous install.
This works with no error. I.e. if we've done an install and then an upgrade with the AI 17.9-built installers, then a subsequent upgrade with the 19.0-built installer works. If the upgrade using the 19.0-built installer is the first time an upgrade has been done, it fails.
Hello Andy,
This is indeed quite a strange behavior.
Currently, I am not aware of any changes in that specific custom action. I will have to double check this with our dev team.
In the meantime, could you please forward me the resources to reproduce this by email at support at advancedinstaller dot com? I would like to have a look over them, if possible.
- a download link for version 1 (built with 17.9)
- a download link for version 2 (built with 17.9)
- a download link for version 4 (built with 19.0)
- the respective .AIP file for each setup
AndyL
Hi Catalin, I've just emailed you some sample installers to reproduce the issue.
AndyL
My emails with files to reproduce the issue keep getting bounced due to size limits exceeded. So it doesn't look like I can send you complete installers to reproduce the issue. I have now emailed some project files that should hopefully allow you to reproduce the issue, if you build them in AI 17.9 and AI 19.0.
AndyL
If there's an alternative way for me to get the installers to you without posting them somewhere publicly accessible, please let me know.
Hello Andy,
Thank you very much for the provided resources.
Once I will have a conclusive answer, I will followup over the email.
nahmed
I am encountering the same issue whenever I try to install on win2019 machine. Please see the log.
AI_IIsConfig: Installing "xxxxxxxxx"
[OPERATION]Application pool 'xxxxxxxxx'
[INFO] Trying to retrieve 'xxxxxxxxx' Application Pool...
 COM Error [0x8007000d]: (The data is invalid.)[ERR] Could not get Admin Section 'system.applicationHost/applicationPools', with entry path 'MACHINE/WEBROOT/APPHOST'.
[ERR] [ERR] Could not get admin section.
[INFO] Trying to create AppPool..
[INFO] Changing commit path to 'MACHINE/WEBROOT/APPHOST'
[OK] Commit done.
[OK] Commit path changed.
 COM Error [0xffffffff]: (Unknown error 0xFFFFFFFF)[ERR] Could not create Application Pool.
Error 4034. There was an error during the IIS configuration process while trying to install Application pool 'xxxxxxxxx'.
MSI (s) (70!B0) [18:00:40:712]: Product: CorrRisk Web Application R5.0.5.0 -- Error 4034. There was an error during the IIS configuration process while trying to install Application pool 'xxxxxxxxx'.
For now, unfortunately, I can not say why this is happening.
As previously mentioned, I have already created a ticket so our dev team can have a look over this scenario.
Once I will have more information, I will update this thread.
AndyL
Has there been any response from the dev team on this issue yet?
Hello Andy,
This issue is currently under investigation on our side, but unfortunately we were not able to find the culprit just yet.
I will let you guys know as soon as I will have more information on this.
Hello Andy,
Please note I have sent you an email regarding this issue.
