Huntsecker
assistant gets stuck
Afternoon Guys,
Started using Advanced Installer, have the enterprise edition. I select Generic installer Project - Enterprise and I select Use the assistant to create project. it prompts me to set the product name and company and then it suggests going to the Builds Page and Highlights it. I select the Builds menu button and that changes all as expected however the assistant is stuck on this and pressing continue does not continue the prompt.
I guess the solution is to go through and work out by my self what to do but the prompts were I nice idea to save me reading the manual :D but looks like its broken at least for me (or maybe I'm holding it wrong in which case please point me in the right direction).
Im on version 19.2.
Cheers
Tom.
Re: assistant gets stuck
Hello Tom,
This is an issue on our side which was already fixed by our development team. The fix will be included in our next major release (19.4 version) that should be out by the end of this month.
As soon as the fix will be released we will notify you on this forum thread.
Hello Tom,
This has been fixed in version 19.4 of Advanced Installer, released on April 26th, 2022.
