MGS
How to display a dialog when a button is pushed
I want to display a dialog when a button is pushed. So I did it like in user guide:In order to display the dialog, the "Display a specific dialog" published control event must be used:
Select the button that will trigger the control event.
Select the “Published Events” tab in the “Control” pane.
Use the [ New... ] button to create a new control event. The Edit Control Events Dialog will be displayed.
Configure the control event as follows:
Name = Display a specific dialog
Argument = Choose the name of the dialog that you want to display when the button is pushed. If you don't want to use one of the existing dialogs but create a new one, choose the “<NewDialog>” option.
Condition = Leave this field unchanged if you don't want to condition the execution of this control event.
It works but how can I now allow the next button to display not this dialog i.g(dialog1) but the one next to it i.g(dialog2). Where I want this dialog(dialog1) to display only with push Button, and if the button is not pressed and the next button is pressed, the next dialog(dialog2) will display.
Thanks in advance.
Re: How to display a dialog when a button is pushed
I'm afraid I do not quite understand what you are trying to achieve here.
If possible, could you please create a sample project (AIP file) with what you've done so far and forward it to me together with what you'd like to achieve? You can forward it either here or by email at support at advancedinstaller dot com.
MGS
Thank you, I solved the problem :) , it was a repetition in the name of the Dialog.
MGS
Glad to hear everything is working as expected now! :)
