stacyirish
How to use Advanced Installer Jenkins plug in from a jenkinsfile (script)
Hello! I have used the documentation How to configure an Advanced Installer build step into a Jenkins pipeline and Configure a Digital Certificate in a Jenkins Build Step: Jenkins Credentials and Azure Key Vault to successfully set up a Jenkins freestyle project to build my Advanced Installer project and sign everything using my digital certificate that is stored in Azure Key Vault. I would like to do this from a pipeline jenkinsfile script instead of a freestyle project.
I've not gotten far...
withCredentials([string(credentialsId: 'AzureKeyVaultSecret', variable: 'AZURE_KEY_VAULT_SECRET')]) {
  // How to call the Advanced Installer plug in from here?
  // Using the Jenkins snippet generator to "Use a tool from a predefined tool installation" only generates the following line:
  // tool name: 'AdvancedInstaller_20.8', type: 'caphyon.jenkins.advinst.AdvinstInstallation'
Any help is appreciated.
Re: How to use Advanced Installer Jenkins plug in from a jenkinsfile (script)
After some investigation, it looks like in order to call a plugin in your script, that specific plugin would need to be compatible with the pipeline.
Plugin Compatibility with Pipeline
I will try to add this on our TODO list of improvements and hopefully it will be added in a future version of our Jenkins Plugin.
stacyirish
Thanks for the reply, Catalin.
Just to clarify, at the current time, the only way I can build my Advanced Installer package and digitally sign it with my certificate that is stored in Azure Key Vault from my jenkinsfile script would be to create a batch command and call Advanced Installer from the command line with a command file that contains the Azure Key Vault Secret?
AdvancedInstaller.com /execute <path_to_project_file> <command_file_path> [-nofail]
This is not really preferred as I have to have a file containing the secret put somewhere too many people can get to. If you have some alternative solutions, I would appreciate them.
Meanwhile, I look forward to updates to the Advanced Installer Jenkins Plugin.
That would indeed be the only solution currently available.
If there's anything else I could help you with, please let me know and I will gladly assist.
agwin
Hello @Catalin,
Has there been any progress on using the plugin from a Jenkinsfile?
Also, if I were to use the CLI, is it dependent on building in a Windows environment? All of our Jenkins build agents are currently running Linux, so I'd need to find another solution.
Thank you.
