witekgb
Updater.exe log/debug file
Is there a way to get debug information from updater.exe? We are having a problem trying to troubleshoot why our updater is not working properly - it always says the software is up to date when it's not and we cannot figure out why it says this without looking at some kind of a debug file to troubleshoot what steps the updater has gone through. Any help is much appreciated.
Re: Updater.exe log/debug file
In order to achieve this, you can open your "Updates Configuration" project, go to "Update Installer" tab and then use the following command line in the "Command line:" field:
/L*V "log_file_location"
Also, in what regards your problem, at a first sight, I would say that this is caused by a wrongly configured "Update Installed Detection" (see "Update Installed Detection" tab).
koutnypetr
I am facing similar issue and provided advice is not enough. I have had an issue in my update file but since I run my updater silently, I was not able to find any log and suggested solution applies on a specific update. But since updater is having issues even finding an installer, we do need some kind of another log. Where can we find it please?
I believe I responded to a similar question you asked here.
