raminmjj
Pin to taskbar is not working in windows 10
Hello.
"Automatically Pinned" is not working properly in Windows 10.
Re: Pin to taskbar is not working in windows 10
Indeed, the Automatically Pinned to Taskbar for a shortcut is not working on Windows 10.
We will further investigate if there is any programmatically method to automatically pin a shortcut to the Taskbar.
sammykp
Dan wrote:Hello,
Is this issue resolved yet?
I am using latest version but automatic pin feature isn't working for windows 10. Any workaround?
We have further investigated this and starting with Windows 10 we didn't found any public API which can be used to automatically pin a shortcut to taskbar. It seems this is because Microsoft doesn't allow any programmatically customization of the taskbar. The Windows 10 taskbar can be only manually customized by the user.
Justin
Hello Dan,
I have Advanced Installer Architect license. Could you help to provide the "auto pin to taskbar in window 10" is workable or not for the lastest version? Thanks!
Best Regards,
Justin
Justin
Hi Dan,
I'm using Advanced Installer 17.5 version on window 10 and happened the same problem. Could you help for this. Thanks!!
Best Regards,
Justin
Hi Justin,
I am afraid we weren't able to find any solution for this option on Windows 10.
So, this option will not apply/work on Windows 10 machines. Thank you for your understanding.
Justin
Hi Daniel,
Thanks for your kindly reply. I met a problem is that the old version is pinned to taskbar but after updating to new version the pinned link is unavailable.
Do you have some suggestions how to keep the pinned link available on new version? Thanks!!
Best Regards,
Justin
Hello Justin,
Starting with Windows 10, a lot of programmatic ways of pinning an executable to taskbar have stopped working (e.g. PowerShell scripts, VBScripts, C# solutions, etc.).
An example of the above would be this StackOverflow thread.
Unfortunately, as my colleague Daniel mentioned above, we were not quite able to find a solution for this problem on Windows 10.
