Re: Learning Advanced Installer - Resources
Installer Analytics - see how many users install your application daily. The only Windows Installer dedicated analytics platform allows you to uncover the missing piece of business intelligence in understanding how your application gets deployed to your users' computers.
Identify and update package resources - multiple selection on your search results
VladDyve
I have a question. If I create a project with an Enterprise version and I made specific customization for dialog themes. and everything works.
Is possible to build this project from command line with a professional license installed on a computer?
Thnaks
Hello Vlad and welcome to Advanced Installer forums,
Please note that you will not be able to edit your project with a lower version of Advanced Installer than the one that has been used to create the project.
For details, please check the project type article.
If you have other questions please let us know.
Find out how to speed up your application installation with just one click!
MSI Fast Installation Video
Configuring PRE and POST build events.
Updating the contents of a file - TXT file updates
Search and update INI files. No coding required.
kenedy
Its absolutely helpful post.Thanks a lot for sharing such a great info.
Graduated from Soran University with First Class Degree with Honours in Computer Science.
You are always welcome.
