Re: Unable to load MSBuild Assemblies during importing Visual Studio Project
You're always welcome, Robert.
Rauldoce
Hello, I have just installed Version 15.8 and, for the first time after packaging several other VSNet Solutions I am experiencing the same error message.
Since it happens during import, I do not have an AIP-file. A few details on my environment:
- Installed VS 2015 and VS 2017
- the solution is now in VS2017 and had been imported from a previous VS2015 Project.
Unfortunately, I can not say why this happens. In order for me to further investigate this, could you please forward me the solution that you are trying to import and that generates such an error by e-mail at support at advancedinstaller dot com?
Also, is this reproducible with any solution that is imported from Visual Studio 2015 to Visual Studio 2017, or is this particular to one solution?
Thank you for providing these details. I am pretty sure this will be of help for investigating the root cause of this issue.
Rauldoce
I have found a solution in the meantime. I changed the following lines in the SLN-file:
Microsoft Visual Studio Solution File, Format Version 12.00
# Visual Studio 15
VisualStudioVersion = 15.0.28307.489
MinimumVisualStudioVersion = 10.0.40219.1
Project("{F184B08F-C81C-45F6-A57F-5ABD9991F28F}") = "VISTA_Forms", "VISTA_Forms\VISTA_Forms.vbproj", "{156F1794-6A08-4A92-B81F-29CEBD24F60F}"
EndProject
Global
EndGlobal
Due to import from VS2015, the version did not correspond.
Advanced Installer: Great product
I have further tested this and I was able to reproduce the described behavior. The issue seems to appear when, on the machine, there are two versions of Visual Studio installed, side by side (e.g. 2015 and 2017, 2017 and 2019, etc.).
Thank you for your followup on this and for sharing your valuable solution with us. This solution was of high importance for us as it led to us being able to isolate the issue and finding the root cause of it. With that being said, we were able to fix this (hopefully, this will be available starting with the next version of Advanced Installer).
For a quick-fix to this problem, do not hesitate to send us an e-mail at support at advancedinstaller dot com.
Daniel wrote: Mon Feb 18, 2019 1:25 pm Hello John,
Thank you for your valuable feedback. Indeed it seems our application fails to import a SLN when VS 2017 and VS 2019 are installed side by side.
We will try to add a fix for this issue in a future version of Advanced Installer, thank you for helping us to isolate this. As soon as a fix is out we will update this thread.
This was fixed in 15.8 version of Advanced Installer, released on March 20th, 2019.
francis.matamoros
Hello, I just upgraded Advanced Installer to version 15.8 because I could never import a Visual Studio solution and I keep getting the same error:
Thank you
Hello Francis,
I have tried to test this, but I was not able to reproduce the described behavior. In order for us to continue our investigations, could you please forward me the following information:
- on what machine are you testing this? Are you testing this on a Windows 10 machine or on an older version of Windows?
- which version of Visual Studio you have installed on your machine? If you have more than one version installed, please enumerate all of them.
- if possible, please forward me the solution and all of the projects included in your solution (we need only the project files without their source code files) by e-mail at support at advancedinstaller dot com.
- also, could you go to Control Panel and tell me what version of "Microsoft Visual Studio Installer" version you have installed?
francis.matamoros
Hello Catalin, here you have the required information:
1. Winver: Windows 10 Pro version 1809 (compilation 17763.437)
2. Visual Studio 2017 (15.9.11)
Visual Studio 2008 Professional (older projects - I don't use it)
3. Microsoft Visual Studio Installer version 2.0.3287.312
I passed to email one sample project.
Thank you
Hello Francis,
Thanks for the provided files.
Before starting to investigate this on our end, could you please try to download the latest version of Advanced Installer that we have just released (15.9) and retest the import functionality with it?
https://www.advancedinstaller.com/download.html
If that is of no help, just let me know so I can start investigating this.
francis.matamoros
Hello, I installed the latest version this morning and checked that it still does not work.
Hello Francisco,
Until now we were unable to replicate the import error with Advanced Installer 15.9. However, we will continue investigating this and get back to you as soon as we have a conclusion. Thank you for your further patience.
Until then, as a workaround you can try to use our Visual Studio extension to create the setup project or simply create the setup project within Advanced Installer from scratch.
