AnypadDev
MSI - Custom Action - Fixed Filename for Attached PowerShell Script
We are using "PowerShellPostInstall" custom action, attaching a ps1 script, to run some logic and file I/O after installation. When Advanced Installer reaches this step, it will write ps1 files (the attached script and another script for preparing functions AI_GetMsiProperty, AI_SetMsiProperty) into the %TEMP%. However, we found that it is writing ps1 files with random names pss{random}.ps1.
Is there a way to make Advanced Installer use a fixed name when writing these files to %TEMP%? We have a client that needs to whitelist ps1 files being executed so a random name for each execution won't work.
[edit] Alternatively, is it possible to sign these files instead?
Software Version: 16.4.1
Edition: Professional
Re: MSI - Custom Action - Fixed Filename for Attached PowerShell Script
Unfortunately, I'm afraid I am not aware of any way of doing so.
We have recently added support for signing your PowerShell files in version 17.1 of Advanced Installer.
