My setup integrates an msi prerequisite, which is set as feature-based.
I'm having an issue when launching my setup with System user: only in this case, the prerequisite setup fails to launch (or perhaps even to extract: it should be launched with logging flags itself, but that log isn't created at all).
When launching my setup with verbose logging flags, all I can see at the end of the log is:
Do you have any idea?MSI (c) (84:A4) [18:28:38:107]: PROPERTY CHANGE: Adding AI_MISSING_PREREQS property. Its value is 'PrerequisiteName x64'.
MSI (c) (84:A4) [18:28:38:107]: PROPERTY CHANGE: Modifying AI_FOUND_PREREQS property. Its current value is '.NET Framework 4.6.1'. Its new value: '.NET Framework 4.6.1| PrerequisiteName x86'.
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2205 2: 3: AI_TempFile
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2228 2: 3: AI_TempFile 4: SELECT `Property` FROM `AI_TempFile`
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2205 2: 3: AI_XmlLocator
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2228 2: 3: AI_XmlLocator 4: SELECT `Property` FROM `AI_XmlLocator`
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2205 2: 3: AI_ChainedPackage
MSI (c) (84:A4) [18:28:38:123]: Note: 1: 2228 2: 3: AI_ChainedPackage 4: SELECT `ChainedPackage` FROM `AI_ChainedPackage`
MSI (c) (84:A4) [18:28:41:750]: Doing action: FatalError
Action start 18:28:41: FatalError.
MSI (c) (84:40) [18:29:15:631]: PROPERTY CHANGE: Deleting AI_LOG_CHECKBOX property. Its current value is '1'.
Action ended 18:29:16: FatalError. Return value 1.
MSI (c) (84:A4) [18:29:16:380]: Doing action: AI_CleanPrereq
Action start 18:29:16: AI_CleanPrereq.
MSI (c) (84:C0) [18:29:16:380]: Invoking remote custom action. DLL: C:\WINDOWS\TEMP\MSI2197.tmp, Entrypoint: CleanPrereq
Action ended 18:29:16: AI_CleanPrereq. Return value 1.
MSI (c) (84:A4) [18:29:16:427]: Doing action: FatalError
Action start 18:29:16: FatalError.
Action ended 18:29:16: FatalError. Return value 2.
MSI (c) (84:A4) [18:29:16:427]: Note: 1: 2205 2: 3: Environment
MSI (c) (84:A4) [18:29:16:427]: Note: 1: 2228 2: 3: Environment 4: SELECT `Environment`,`Component_` FROM `Environment`
MSI (c) (84:54) [18:29:16:458]: Destroying RemoteAPI object.
MSI (c) (84:04) [18:29:16:474]: Custom Action Manager thread ending.
=== Verbose logging stopped: 24/05/2021 18:29:16 ===
Thanks a lot!
