AI_New_User
Consecutive Patches
I saw the previous thread with this title but I have a different problem.
I needed to create upgrade patch 55724 to patch 55824. So I created a new MSI for 55824 and kept existing product code. Just like I did with the MSI for 55724 when I created that patch. Then I created a patch using the MSI from 55724 and the MSI from 55824. When I build, I get this error:
Checking builds status
Build required.
Building package:
C:\Users\clothere.grammont\source\repos\Ecat.WPF.Core\ECATSetup_Temp\Ecat6Setup-UpdatePatchFiles\Ecat6Setup_Patch55824.msp
Running MSI patch compatibility tests
Creating PCP database
Creating MSP
***** Log starting: 2021-08-29 11:15:32 *****
  INFO: Using Pcp Path: MyPath\MyAppSetup_Patch55824.pcp.
  INFO: Using Temporary Directory: MyPath\AppData\Local\Temp\~pcw_tmp.tmp.
  INFO: Passed all of the main control parameter validation to PatchWiz, now calling the next 5 phases.
  INFO: Phase I:	Entered validation and processing phase.
  INFO: 		Validation of Pcp.
  INFO: 		MinimumRequiredMsiVersion is 200.
  INFO: 		SEQUENCE_DATA_GENERATION_DISABLED is 1.
  INFO: 		ListOfPatchGUIDsToReplace is .
  INFO: 		ListOfTargetProductCodes is *.
  INFO: 		MsiFileToUseToCreatePatchTables is .
  INFO: 		PatchGUID is {DDCFF224-632E-4086-A4F8-AE5A73BD4F44}.
  INFO: 		PatchOutputPath is MyPath\MyAppSetup_Temp\MyAppSetup-UpdatePatchFiles\MyAppSetup_Patch55824.msp.
  INFO: 		PatchSourceList is PatchSourceList.
  INFO: 		PATCH_CACHE_DIR is .
  INFO: 		AllowDualPatch is 0.
  INFO: 		AllowProductCodeMismatches is 1.
  INFO: 		AllowProductVersionMajorMismatches is 0.
  INFO: 		ApiPatchingSymbolFlags is 0.
  INFO: 		DontRemoveTempFolderWhenFinished is 0.
  INFO: 		IncludeWholeFilesOnly is 1.
  INFO: 		PATCH_CACHE_ENABLED is 0.
  INFO: 		OptimizePatchSizeForLargeFiles is 0.
  INFO: 		TrustMsi is 0.
  INFO: 		AllowLaxValidationFlags is 0.
  ERROR: TargetImages.Target = 'MyAppSetup_2': PackageCode {D8744254-172A-4BEA-8F34-1C333BBB510E} is not unique.
  INFO: Temporary folder is about to be cleaned out and deleted: MyPath\AppData\Local\Temp\~pcw_tmp.tmp
MsiMsp.exe failed to create the patch file.
Error details
What do I need to do differently?
Re: Consecutive Patches
Please note I have answered your other thread in which I have explained how to create consecutive patches:
Tutorial on how to create consecutive patches.
