ZENIX
Pre-Installation Post-Installation Setting
I want to install only to the first directory of the disk.
C:/.../ I Want To Force It, Not Directory How Can We Do It?
I want to install the MySQL Installer 8.0.26 file automatically and with the desired setting and password.
It is possible to run it as cmd, I want to install mysql first and then have it installed on mandatory disks. how can I do that ?
https://dev.mysql.com/doc/mysql-monitor ... ution.html
Re: Pre-Installation Post-Installation Setting
In order to achieve this, you can modify the default path by going to "Install Parameters" page --> "Application folder" as it follows:
[ProgramFilesFolder][Manufacturer]\[ProductName]
to:
[WindowsVolume]
In order to achieve this, you can add MySQL as a pre-install prerequisite.
Creating a Professional package
