carlosLiu
Error when upgrading the installer project
I have a project which is based on Advanced Installer v13.8, now I want to upgrade it to use Advanced Installer v18.8, but after I open the project with v18, below info is shown in the Notification pane
- Project converted from a previous version (13.8). After saving it with the current version of Advanced Installer (18.8.1) you will not be able to open it in previous versions.
- Missing required item: InstallLogoIcon2 Type: Property.
- Missing required item: WaitLogoIcon Type: Property.
- Packages built with this version of Advanced Installer can be installed only on Windows Vista or newer. For deploying packages on older operating systems, please use Advanced Installer 15.9.
The "missing required item " are in red, how can I solve the problem?
Re: Error when upgrading the installer project
Hello Carlos and welcome to our forums,
To be fully honest with you, I am not really familiar with that error (I do not recall ever encountering it).
Just by the look of it, I would assume it is somehow related to the "Themes" page --> "Images" tab.
If possible, could you please forward me a copy of your .AIP file by email at support at advancedinstaller dot com so I can further investigate this?
