bloognoo
AI Devops Task Installer Exception
Hi All,
I'm trying to install the AI task on an On-Premise Azure Devops server using 'caphyon.AdvancedInstaller-BuildTask-2.0.7.vsix'.
The installer reports
*Install Failed*
The install of '' was not successful for all the selected products.
Element 'Asset' has attribute 'Type' with value 'task/node_modules/azure-pipelines-tool-lib/node_modules/azure-pipelines-task-lib/mock-toolrunner.ds' whose length is greater than the maximum value of 100.
The log is as follows:
26/04/2022 14:12:08 - Microsoft VSIX Installer
26/04/2022 14:12:08 - -------------------------------------------
26/04/2022 14:12:08 - vsixinstaller.exe version:
26/04/2022 14:12:08 - 17.1.4058
26/04/2022 14:12:08 - Command line parameters:
26/04/2022 14:12:08 - C:\Program Files (x86)\Microsoft Visual Studio\Installer\resources\app\ServiceHub\Services\Microsoft.VisualStudio.Setup.Service\VSIXInstaller.exe,C:\Users\hfrench\Downloads\caphyon.AdvancedInstaller-BuildTask-2.0.7.vsix
26/04/2022 14:12:08 - Skipping product Microsoft.VisualStudio.Product.BuildTools (3cf3ed11) since it does not support extensions
26/04/2022 14:12:08 - Skipping product Microsoft.VisualStudio.Product.BuildTools (63aac8b7) since it does not support extensions
26/04/2022 14:12:08 - Initializing Install...
26/04/2022 14:12:09 - Microsoft.VisualStudio.ExtensionManager.InvalidExtensionManifestException: Element 'Asset' has attribute 'Type' with value 'task/node_modules/azure-pipelines-tool-lib/node_modules/azure-pipelines-task-lib/mock-toolrunner.d.ts' whose length is greater than maximum value of 100.
at Microsoft.VisualStudio.ExtensionManager.ExtensionImpl.VerifyString(String value, ErrorInfo info, Boolean isRequired, Int32 maxLength, String defaultValue)
at Microsoft.VisualStudio.ExtensionManager.ExtensionImpl.ExtractLocaleManifestData(ILanguagePackManifestSchema manifest, String localeRelativeRoot, Boolean localeSpecific)
at Microsoft.VisualStudio.ExtensionManager.ExtensionImpl.ExtractManifestData(PackageManifest manifest)
at Microsoft.VisualStudio.ExtensionManager.ExtensionImpl.ReadPackageManifest(XmlReader reader)
at Microsoft.VisualStudio.ExtensionManager.ExtensionImpl.ReadManifest(Stream manifestStream)
at Microsoft.VisualStudio.ExtensionManager.InstallableExtensionImpl.ReadVSIXManifestFromPackage(Stream stream, CultureInfo preferredCulture)
at Microsoft.VisualStudio.ExtensionManager.InstallableExtensionImpl..ctor(String path, CultureInfo preferredCulture)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.CreateInstallableExtension(String extensionPath, CultureInfo preferredCulture)
at Microsoft.VisualStudio.ExtensionManager.ExtensionEngineImpl.CreateInstallableExtension(String extensionPath)
at VSIXInstaller.ExtensionService.GetInstallableData(String vsixPath, String extensionPackParentName, Boolean isRepairSupported, IStateData stateData, IEnumerable`1& skuData)
at VSIXInstaller.ExtensionPackService.IsExtensionPack(IStateData stateData, Boolean isRepairSupported)
at VSIXInstaller.ExtensionPackService.ExpandExtensionPackToInstall(IStateData stateData, Boolean isRepairSupported)
at VSIXInstaller.App.Initialize(Boolean isRepairSupported)
at VSIXInstaller.App.Initialize()
at System.Threading.Tasks.Task`1.InnerInvoke()
at System.Threading.Tasks.Task.Execute()
--- End of stack trace from previous location where exception was thrown ---
at Microsoft.VisualStudio.Telemetry.WindowsErrorReporting.WatsonReport.GetClrWatsonExceptionInfo(Exception exceptionObject)
Re: AI Devops Task Installer Exception
Unfortunately, I can not say for sure why this is happening, as I have never encountered this error before.
Please allow me some more time to discuss this with our dev team and I will followup on this thread as soon as I will have more information.
Hello Harry,
I have followed this up over the email (support at advancedinstaller dot com is our email address).
