Hi
We use the updater feature with "Support Service". So users can update without elevating.
Unfortunately this does only work if the code sign certificate of updater is same as the new setup, otherwise uac prompt for elevating is shown.
Our certificate (Azure trusted signing) is only valid for one year.
So if the certificate is reissued from azure, updating without elevating is not possible. Do you have any hint to handle this?
Thank you
Kind regards,
Derrin
