vaine0
Paths and Source Control
Let's say, that your development environment paths do not match your build environment paths, and let's say that your advanced installer project is under source control. Now let's say that inside your advanced installer project, you are building path variables to point at the bin wherein your executables are being dumped, post build. So you have 2 different file structures, i.e.
c:\developerMachine\source\bin
c:\buildMachine\source\bin
so, respectively
[SOURCE_ROOT] = c:\developerMachine
[SOURCE_ROOT] = c:\buildMachine
Ok, simple enough... that is until you commit changes to the project. Is there a separate file which contains these path variable definitions, so that it could _not_ be under source control? If not, is there another solution or perhaps could this be a future feature?
vaine0
Re: Paths and Source Control
Ignore the above.
