Advanced Installer allows you to perform a search for a folder at install time.
Here is how it could be done:
- In the "Search" page, use the [ New Search ] toolbar button to schedule a search.
- Select the resulted search property.
- Use the [ Add Location ] toolbar button and select the "Folder" option.
- Edit the "Path" field (Directory Properties pane) to the path of the folder to be searched. This field is of formatted type. Use the [...] button to inset reference to a file, folder or property.
If the search is successful the resulted property will contain the path of the folder, otherwise it will be empty.
