joefio
Upgrade an application without GUID
I am currently rewriting the installer for my application with advanced installer. The application does not appear to have a GUID. The NSIS installer used previously checked for a different registry key, which had the install path as its value, to determine if it was an update.
How would I go about setting up updates for an application that does not have a GUID? Advanced installer looks for an Upgrade code, but the application I am trying to update does not have one. In this case, I would need a way to check if a registry path exists to determine if it is an update, and update to the path specified in the registry key. But i am not sure how to do so. Any guidance would be appreciated.
Re: Upgrade an application without GUID
Indeed, if I remember correctly, the NSIS packages create an uninstaller.exe which is called on upgrade.
To achieve what you want, we can create a "Registry search" in the "Searches" page.
You can then update the registry key either through the "Registry" page (if you can recreate the path) or through a "Custom Action" (e.g. a PowerShell script).
joefio
Catalin wrote: Fri Apr 28, 2023 11:53 am Hello,
This is very helpful, thank you for the response.
You are always welcome!
Glad I was able to assist.
