I try to do a very simple installation where I copy template files in the application folder and create a shortcut to another application. I added a dialog to ask user to select the folder where this other application was installed. If I keep the defaullt folder location the install works but the shortcut is not created. if I select another location then same thing if I ran the install outside the Advanced Installer but when I ran the install with the log I saw the error "The directory entry does not exist in the Directory table". Can you take a look on my aip file?
