I am using Advanced Installer 6.2 on Win XP SP3. I have several file associations to create during installation. After installation when I click the files whose association should be added, the installer itself is invoked instead of the registered program which should handle the file extension. In registry in the folder (for example) - My Computer\HKEY_CLASSES\...\shell\open\command there are two entries
(Default) REG_SZ "C:\Program Files\Sun\JavaFX Production Suite\ViewerFX\ViewerFX.exe" "%1"
command REG_MULTI_SZ d1nJV&!mO@d9b)ctlem8>P,{a%`b^}=59%nlIE0V@ "%1"
when I manually delete the command entry everything works fine. Do you know where the gibberish in the command entry comes from and what does it mean?
Thanks for any help.
Pavel
