we have a problem creating a patch with more than 6 targets. The build process is crashing with following exception:
The Error details are:....
ERROR: Cannot create patch file for 'C:\Setups_V6\Handwerk\images\TemplateCl\Handwerk.exe' at 'C:\Users\AREIMC~1\AppData\Local\Temp\~pcw_tmp.tmp'.
ERROR: The Last Error Received is: 0x8 (8)
INFO: Temporary folder is about to be cleaned out and deleted: C:\Users\AREIMC~1\AppData\Local\Temp\~pcw_tmp.tmp
ERROR: Internal PatchWiz Error occurred.
ERROR: The Last Error Received is: 0x91 (145)
ERROR: During cleanup, could not delete the temporary folder: C:\Users\AREIMC~1\AppData\Local\Temp\~pcw_tmp.tmp.
MsiMsp.exe failed to create the patch file.
Error details
Best regards,MsiMsp.exe failed to create the patch file.
Advanced Installer 13.7 build 75982
*** Stack Trace (x86) ***
[0x75f696c2] RaiseException()
[0x01e55519] -----
[0x0113aa38] -----
[0x00a7c2f6] -----
[0x0113a6d8] -----
[0x00c732ba] -----
[0x00c732c9] -----
[0x00c72a6f] -----
[0x00a7adf4] -----
[0x00a75ed7] -----
[0x01e8e0e1] -----
[0x01e933cc] -----
[0x01711ff8] -----
[0x01712129] -----
[0x77220609] RtlSubscribeWnfStateChangeNotification()
[0x772205d4] RtlSubscribeWnfStateChangeNotification()
[0x008a0000] MODULE_BASE_ADDRESS
Alex
